本指南有最近更改,您可查看未经巡查的最新版本。
简介
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
你所需要的
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to lift the AirPort/Bluetooth connector out of its socket on the logic board.
20等其他人完成本指南。
