简介
Gebruik deze handleiding om een oude of kapotte batterij te vervangen. Neem, als je batterij gezwollen is, de juiste voorzorgsmaatregelen.
你所需要的
Verwijder de volgende tien schroeven die de onderste behuizing aan de bovenste behuizing bevestigen:
Zeven 3 mm lange Phillips schroeven.
Drie 13.5 mm lange Phillips schroeven.
在这个步骤中使用的工具:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Drie Pentalobe schroeven bevestigen de batterij aan de bovenste behuizing. Deze kunnen worden verwijderd met deze speciale schroevendraaier.
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
165等其他人完成本指南。
由衷感谢以下译者:
100%
Thomas Keulemans正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
20条评论
Changing this battery for a friend went as smooth as silk. I've done this many times before so that was no surprise, but now the battery (bought from ifixit) shows only 85% charge even after being left all night to charge, and the charger stopped charging and shows the light on the charger shows green.
What have we done wrong and what do we need to do about it?
You need to calibrate the new battery. Charge until it won't charge any more. Unplug the computer and leave it until it puts itself to sleep from low battery. Make sure your settings are as low a threshold as possible (3%) I think is the minimum. Then plug it in and charge back to 100%.
Further note: we tried running off the battery, and when it was at 44% tried to recharge it using another charger that we knew was working. The battery indicator says the battery is not charging.
Hola buenas. necesito comprar una bateria para mi macbook pro 15", de mediados del 2009, en el que la tapa se abre entera. no se que modelo de bateria es, me podriais decir el nombre o referencia que lleva por favor??? me estoy volviendo loca buscando por internet.
