跳转到主内容
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement
你所需要的
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement: 步骤 2 中的图像 1,1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: 步骤 3 中的图像 1,2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
结论
96等其他人完成本指南。
一条评论
How is this easier than removing a drive? Its both relatively easy. Otherwise good guides.
Jr. - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 9
过去 30 天: 30
总计 40,943
