简介
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  4. Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
结论
86等其他人完成本指南。
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 17
过去的30天: 79
总计 37,524
