跳转到主内容
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
  1. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
  2. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
  3. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Peel the camera cable off the adhesive securing it to the optical drive.
  4. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 4 中的图像 2,2
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  5. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 5 中的图像 1,2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  6. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  7. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
  8. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 8 中的图像 1,2 MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 8 中的图像 2,2
    • Lift the optical drive from its left edge and pull it out of the computer.
    • When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
  9. MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Optical Drive Replacement: 步骤 9 中的图像 1,1
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 761
