跳转到主内容
MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 2 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 2 中的图像 2,2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 3 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 3 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 3 中的图像 3,3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 5 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 5 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 5 中的图像 3,3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, AirPort/Camera Cables: 步骤 6 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, AirPort/Camera Cables: 步骤 6 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, AirPort/Camera Cables: 步骤 6 中的图像 3,3
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
    • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  7. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 7 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 7 中的图像 2,2
    • Peel the right rubber cover up off the fan and fold it out of the way.
  8. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 8 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 8 中的图像 2,2
    • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
    • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
  9. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 9 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 9 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 9 中的图像 3,3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
  10. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, I/O Board Cable (Top): 步骤 10 中的图像 1,1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  11. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 11 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 11 中的图像 2,2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  12. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 12 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 12 中的图像 2,2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  13. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 13 中的图像 1,1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
  14. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement, Right Fan: 步骤 14 中的图像 1,1
    • Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
    • One 5.0 mm screw with a 2.0 mm long shoulder
    • One 4.0 mm screw with a wide head
    • One 4.4 mm screw
  15. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 15 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 15 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 15 中的图像 3,3
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  16. MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 16 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 Right Fan Replacement: 步骤 16 中的图像 2,2
    • Lift the fan and push it gently towards the back edge of the MacBook to free the fan cable from its socket.
    • The fan cable may be adhered to the logic board—to avoid tearing the cable, gently peel it up while lifting the fan.
    • Remove the fan.
结论
44等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
7条评论
Great tutorial. I did not notice the screw length in the beginning. Thanks. :)
Strange noise came out of my mac. I found a screw on my right fan fell off and got stuck in the right fan.
James Bond - 回复
Complimenti davvero, una guida veramente ben fatta. Il mio mac ringrazia :)
Gianluca Bruno - 回复
completed my first mac repair ever, so excited.
Franklin Byaruhanga - 回复
I was hearing a strange buzzing / grinding noise coming from my right speaker. After ensuring it wasn’t the speakers, I realized it was the fan (would only start making the noise when the fans were kicking into high gear). I opened it up and found that one of the screws on the right fan wasn’t attached to the logic board: Step 14, top right screw (orange) attaches to a silver nut (?) which should be attached to the logic board. The adhesive that attaches the nut to the logic board had detached! Gotta find what type of adhesive I need to get for this, but putting this here for anyone with a similar problem.
Rachel - 回复
Thank you so much - I used this to access and clean (but not replace) the fan.
CCC - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 84
过去 30 天: 325
总计 46,072
