跳转到主内容
MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 2 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 2 中的图像 2,2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 3 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 3 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 3 中的图像 3,3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 5 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 5 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 5 中的图像 3,3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): 步骤 6 中的图像 1,1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 7 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 7 中的图像 2,2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 8 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 8 中的图像 2,2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 步骤 9 中的图像 1,1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
结论
3等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 22
过去 30 天: 102
总计 8,959
