跳转到主内容
MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 步骤 1 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 步骤 1 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement, AirPort/Camera Cables: 步骤 1 中的图像 3,3
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
    • The cable connection points are very fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  2. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 2 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 2 中的图像 2,2
    • Peel the right rubber cover up off the fan and fold it out of the way.
  3. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 3 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 3 中的图像 2,2
    • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
    • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
  4. MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 4 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 4 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2015 AirPort/Camera Cables Replacement: 步骤 4 中的图像 3,3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    • On reassembly, there should be enough adhesive still on these cables to stick them back down to the fan.
结论
另外一个人完成了本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 360
