跳转到主内容
MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement: 步骤 2 中的图像 1,1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement, Battery Connector: 步骤 3 中的图像 1,1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement: 步骤 4 中的图像 2,2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 3,3
    • Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
    • In a similar fashion, remove the I/O board cable from its socket on the I/O board.
  6. MacBook Pro 15" Retina Display Mid 2014 IO Board Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the I/O board cable from the MacBook Pro.
结论
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,892篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 6,221
