跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement
你所需要的
    1. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement, housing base: 步骤 1 中的图像 1,1
      • Remove the following P5 pentalobe screws securing the bottom case to the MacBook Pro:
      • Eight 3.0mm screws
      • Two 2.3mm screws
      询问修复机器人
      添加评论
    2. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 2 中的图像 1,1
      • Using the edge closest to the clutch cover, lift the bottom case off the MacBook Pro.
      • Set the bottom case aside.
      询问修复机器人
      添加评论
    3. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 3 中的图像 1,1
      • Peel off the warning sticker over the battery connector.
      询问修复机器人
      添加评论
    4. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 4 中的图像 2,2
      • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
      • Bend the battery cables back and out of the way so the battery connector doesn't accidentally contact the logic board.
      询问修复机器人
      添加评论
    5. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 5 中的图像 1,1
      • Use a spudger or tweezers to slide the three AirPort antenna cables straight out of their sockets on the AirPort board.
      • The connection points on the cables are very sensitive. Make sure you only pick up the plug, not the port or the cable.
      • When reassembling, carefully align the connectors over the socket and press down firmly with your thumb or the flat end of a spudger.
      询问修复机器人
      添加评论
    6. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 6 中的图像 1,1
      • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board toward the fan.
      • Be sure to slide the connector parallel to the logic board. It is best to slide it first on one side and then on the other side so that it gradually moves out of the socket. Do not pry up or you will damage the connector.
      询问修复机器人
      添加评论
    7. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 7 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 7 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 7 中的图像 3,3
      • Insert the flat end of a spudger under the rubber sleeve on the right fan heatsink.
      • Run the spudger under the entire length of the casing to loosen the adhesive.
      • Lift the sheath and fold it back so you can access the cables underneath.
      询问修复机器人
      添加评论
    8. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 8 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 8 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 8 中的图像 3,3
      • Use your fingers to pull the AirPort/camera cables up and away from the fan.
      • The cables are glued to the fan, so you must pull carefully to avoid damaging them.
      • Carefully unroute the cables from their plastic guides.
      询问修复机器人
      添加评论
    9. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 9 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 9 中的图像 2,2
      • Use the tip of a spudger to release the display data cable latch and rotate it toward the DC-in.
      • Unplug the display data cable from its socket on the logic board.
      • Do not lift the display data cable as its socket is very delicate. Disconnect the cable parallel to the face of the logic board.
      询问修复机器人
      添加评论
    10. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 10 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 10 中的图像 2,2
      • Use tweezers to lift the rubber covers over the left and right display hinges.
      询问修复机器人
      添加评论
    11. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 11 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 11 中的图像 2,2
      • Remove the two 3.1mm Torx T5 screws securing the aluminum hinge brackets.
      询问修复机器人
      添加评论
    12. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 12 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 12 中的图像 2,2
      • Use tweezers to lift up the left and right hinge aluminum brackets.
      询问修复机器人
      添加评论
    13. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 13 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 13 中的图像 2,2
      • Remove the four internal 5.3mm Torx T8 screws (two on each side) securing the display to the upper case.
      询问修复机器人
      添加评论
    14. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 14 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 14 中的图像 2,2
      • Open the MacBook Pro approximately 110° and place it sideways on the table as shown.
      • While holding the display and upper case together with your left hand, remove the last T8 Torx screw from the upper display bracket.
      • Be careful and hold the display and upper case together with your left hand. If you make mistakes, the exposed display/upper case may fall, damaging any of the components.
      • Remove the last Torx T8 screw holding the display to the upper case.
      询问修复机器人
      添加评论
    15. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 15 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 15 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 15 中的图像 3,3
      • Grasp both halves of the device, one in each hand.
      • Gently slide the bottom half of the device forward to separate it from the display assembly.
      • Carefully set each piece aside. Make sure the bottom half is keyboard-side down.
      询问修复机器人
      添加评论
    16. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement, LCD cable: 步骤 16 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement, LCD cable: 步骤 16 中的图像 2,2
      • Lay the device with the display facing you and the plastic latch cover down. Grab the latch cover and slide it all the way to the right, toward the hinge.
      • There are covers on both ends of the clutch cover that are connected like a hinge. You slide the clutch cover to the right and then have to turn it counterclockwise. Then you will hear a click confirming that the clutch cover is released.
      • Lift the cover from below and remove it from the display.
      询问修复机器人
      添加评论
    17. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 17 中的图像 1,1
      • Peel the tape off the cable connector.
      询问修复机器人
      添加评论
    18. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 18 中的图像 1,1
      • Remove the two screws securing the cable to the case:
      • Two Torx T8 screws
      询问修复机器人
      添加评论
    19. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 19 中的图像 1,1
      • Remove the six screws securing the antenna assembly:
      • Six Phillips #00 screws
      • Lift the antenna unit so that the antenna cable connector is visible under the left side.
      询问修复机器人
      添加评论
    20. MacBook Pro 15" Retina Display Mid 2012 LCD Cable Replacement: 步骤 20 中的图像 1,1
      • Grasp the metal bar securing the LCD cable connector and rotate it toward the bottom edge of the display.
      • Pull the LCD cable straight out of its socket on the display.
      • Do not lift the display data cable, its connector is very delicate. Pull the cable parallel to the surface of the display.
      询问修复机器人
      添加评论
结论
Work the steps in reverse order to reassemble your device
取消:我没有完成这个指南。
2等其他人完成本指南。
由衷感谢以下译者:
de en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Stero Size
于08/02/21注册
361 声望
撰写一个指南
1指南评论
Super Anleitung, vielen Dank! Ich hatte einen Kabelbruch in meinem Macbook pro mid 2015 und konnte das Problem Dank Anleitung innerhalb von 45 min selbst beheben. Dank ifixit Werkzeug ohne Kollateralschäden :-)
jesill - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 19
过去 30 天: 113
总计 6,788
