跳转到主内容
MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement, I/O Board: 步骤 1 中的图像 1,2 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement, I/O Board: 步骤 1 中的图像 2,2
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  2. MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: 步骤 2 中的图像 1,3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: 步骤 2 中的图像 2,3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: 步骤 2 中的图像 3,3
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
结论
2等其他人完成本指南。
Brett Hartt
于04/12/10注册
127,897 声望
创作了143篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 454
