简介
Input, Output, Sideput. Whatever kind of putting you will be doing, a faulty I/O board cable is going to severely limit the functionality of your MacBook Pro with Retina display. This guide will show you how to replace it.
你所需要的
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.0 mm
Two 2.3 mm
Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
In a similar fashion, remove the I/O board cable from its socket on the I/O board.
2等其他人完成本指南。
