跳转到主内容
MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: 步骤 2 中的图像 1,1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, Battery Connector: 步骤 3 中的图像 1,1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: 步骤 4 中的图像 2,2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 1,3 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 2,3 MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement, I/O Board Cable: 步骤 5 中的图像 3,3
    • Using the flat end of a spudger, pry the I/O board cable straight up out of its socket on the I/O board.
    • In a similar fashion, remove the I/O board cable from its socket on the I/O board.
  6. MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the I/O board cable from the MacBook Pro.
结论
另外一个人完成了本指南。
Sam Goldheart
于10/18/12注册
471,738 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,547篇指南
一条评论
Will this work with a mid-2012 15” MacBook Pro Retina as well?
Andy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 4,154
