本指南有最近更改,您可查看未经巡查的最新版本。
简介
Removing a few screws will remove this part and allow access to your RAM.
你所需要的
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm PH000 Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
20等其他人完成本指南。
