当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
这个步骤还没有翻译 帮忙翻译一下
Support the display with one hand while removing the following screws:
One 9.5 mm silver T6 Torx screw with threads on only 3 mm of the shaft on the inside of the display hinges.
One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
One 9.2 mm full thread T6 Torx screw securing the iSight cable ground loop to the fan.
110等其他人完成本指南。
2条评论
Excellent job here and iFixit of course gets a nod with the author Walter Galan. It was reassuring to take apart. Having been inside the ole 2008 Penryn beast no biggie. But following the steps here for removing the screen was a treat. Better yet, having the photos to make sure the cables laid down properly when being reattached was reassuring. Thank you Walter!
Completed this in just over 30 minutes and not rushing.
waltdetmer - 回复
