跳转到主内容
MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement
你所需要的
  1. MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement, RAM Shield: 步骤 2 中的图像 1,1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement: 步骤 3 中的图像 1,1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  5. MacBook Pro 15" Core 2 Duo Model A1211 RAM Replacement: 步骤 5 中的图像 1,1
    • Pull the chip directly out from its connector.
    • If there are two RAM chips installed, repeat the above procedure for the second chip.
结论
97等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
一条评论
I just used this guide to add a 4 GB chip to my MBP. Easy peasy. I have a 6 GB MBP. Seems way faster, but could be wishful thinking. But for less than a hundred bucks its not a wasted experiment.
reb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 38
总计 77,264
