跳转到主内容
MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement
你所需要的
  1. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement, Battery: 步骤 1 中的图像 1,1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement, RAM Shield: 步骤 2 中的图像 1,1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 3 中的图像 1,1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement, Upper Case: 步骤 4 中的图像 1,1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 6 中的图像 1,1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 7 中的图像 1,1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 8 中的图像 1,1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 9 中的图像 1,1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 10 中的图像 1,1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement, Left Fan: 步骤 11 中的图像 1,1
    • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 12 中的图像 1,1
    • Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 13 中的图像 1,1
    • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 14 中的图像 1,1
    • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
  15. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 15 中的图像 1,1
    • Lift the left fan up and carefully peel up the tape securing the fan to the heat sink as you go.
  16. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement, Left I/O Board Cable: 步骤 16 中的图像 1,1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  17. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 17 中的图像 1,1
    • Disconnect the three antenna cables attached to the Airport Extreme card.
    • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
  18. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 18 中的图像 1,1
    • Remove the single black T6 Torx screw located just above the Airport Extreme card.
  19. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 19 中的图像 1,1
    • Lift the Airport Extreme card up and slide it out of its connector.
  20. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 20 中的图像 1,1
    • Deroute the Airport antenna cables from their channel in the left speaker.
  21. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 21 中的图像 1,1
    • Peel up the orange hard drive cable from above the ExpressCard cage.
  22. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 22 中的图像 1,1
    • Disconnect the speaker cable from the corner of the left I/O board.
  23. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 23 中的图像 1,1
    • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
  24. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 24 中的图像 1,1
    • Disconnect the large gray and black power cable from the left I/O board.
  25. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 25 中的图像 1,1
    • Remove the following 5 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
  26. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 26 中的图像 1,1
    • Lift up the right side of the left I/O board and slide it out of the computer.
  27. MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Cable Replacement: 步骤 27 中的图像 1,1
    • Turn the left I/O board over and disconnect the short left I/O board cable.
结论
3等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 10,115
