当前版本的文档还未经巡查,您可以查看最新的已查核版本。
使用手来推动电池上的电池释放开关,然后将电池从电脑上移走。
移除三颗相同的十字螺丝。
向上提起记忆门足高的高度来抓住它,并滑动其,将其从拉出。
卸下电池仓闩锁附近的两个2.8 mm Phillips螺丝。
移除下列6颗螺丝
两个10 mm T6 Torx螺丝位于RAM插槽的两侧。
四个14.5毫米十字螺丝 位于铰链附近。
移除电脑插口附近的四颗3.2 mm Phillips 螺丝。
旋转90度,然后移除2颗固定电脑后壳的 3.2 mm Phillips螺丝。
再转90度,然后移除侧面的四颗3.2 mm Phillips螺丝。
切勿猛拉顶壳,顶壳仍然通过排线与逻辑板相连。
抬起壳子的后部,沿着两边用手指撬动,随着手的移动来撬开顶壳。 一旦松开了两侧,您可能需要上下摆动来释放上部的前部的卡扣(有一些隐藏的塑料卡扣需要“特殊照顾”)。
断开触摸板以及键盘连接到逻辑板的排线。
移除顶壳
这个步骤还没有翻译 帮忙翻译一下
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
Remove the following 3 screws:
One 6.2 mm black T6 Torx screw from the right side of the fan.
Two 9.4 mm silver T6 Torx screws from the left side of the fan.
Lift the left fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Disconnect the three antenna cables attached to the Airport Extreme card.
Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
Remove the single black T6 Torx screw located just above the Airport Extreme card.
Lift the Airport Extreme card up and slide it out of its connector.
Deroute the Airport antenna cables from their channel in the left speaker.
Peel up the orange hard drive cable from above the ExpressCard cage.
Disconnect the speaker cable from the corner of the left I/O board.
Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
Disconnect the large gray and black power cable from the left I/O board.
Remove the following 5 screws/standoffs:
Four black T6 Torx screws securing the left I/O board to the lower case.
One 4 mm standoff located between the audio jacks.
Lift up the right side of the left I/O board and slide it out of the computer.
Remove the three silver Phillips screws securing the ExpressCard cage to the left I/O board.
Lift the left I/O board off the ExpressCard cage.
取消:我没有完成这个指南。
另外一个人完成了本指南。
于09/24/09注册
1 声望
创作了636篇指南
徽章: 36
+ 33更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 8,049
