简介
下面是2016/2017年MacBook Pro的扬声器更换指南。2016年10月,苹果推出了全新的MacBook Pro,它拥有全新的设计和功能,包括Touch Bar、新的蝴蝶键盘、显示屏和扬声器。然而这些功能让用户很不爽,因为它们真的很爱坏。苹果公布了键盘和显示屏的更换方案,但很多人都遭遇了扬声器消音的问题。苹果表示,更换扬声器的费用约为600美元,因为它们是粘在顶壳上的,无法单独更换。所以我决定自己更换,并为那些遇到同样问题的人写一篇指南。
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
之后,在扬声器和外壳之间插入一把金属尺子。这样做时要注意不要损坏电池外壳。
你也可以尝试在电池旁边的圆角上用一根吉他弦。
当你在移除扬声器的同时加热外壳,效果最好。让别人在你拉动时拿着吹风机。
按你需要的程度加热,直到胶水稍微松动。
这次更换后的几个月,电池续航时间下降了很多,于是我在天才吧检查了我的MacBook Pro。我问他们,即使我自己更换了右边的扬声器,也能收到更换的电池吗,他们说可以。最终,包括电池和音箱在内的顶箱都换了。但是我担心新的音箱会再次坏掉,因为有时在播放音乐时,音箱会发出噼里啪啦的声音什么的。
44等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
26条评论
is battery draining is related to speaker replacement? as I get it’s not, but just wanted to double-check
I’ll need to do the same replacement after I’ve damaged my speaker when I was opening my MacBook to change thermal paste, so great news you can change to case after a repair like that, thank you
Has anyone done this repair and what there any problems?
I just did it and I did encounter one frustrating thing. In this tutorial it's not mentioned but I did unplug/pull out the power/data line or whatever it is in the middle of the machine. When I went to put it back in, the tab which is there so you can pull on it ripped off! So I was very scared I wasn't going to be able to hook it back in and with some frustration managed to get it. Just be very careful with every step of this process.
wangmeow -
Where can I buy the right-side speaker component, 2017 model? As you noted in the 3rd step section, you find the structural differences between 2016 and 2017models. When I search the 2017 model right-side speaker in ifixit. com here, the component seems to be only 2016 model as below:
MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
Also, do you have a video tutorial of replacing speakers? If then, much appreciated!
