简介
Use this guide to replace a broken AirPort/Bluetooth board.
你所需要的
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Be patient on disconnecting this one. It worked for me step by step, little by little.
I used the nails of thumb and pointer finger simultaneously - worked pretty fine
I whittled down ends of two wooden strips to use, along with my fingernails to start with. I used halves of a wooden clothespin, but popsicle sticks should work too.
Mike Baker - 回复
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Great tip, I did that too
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
On my MacBook Pro, the connector seems to be an integral part of the battery.
I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
Dissambling my MacBookPro Premium Mid 2012 (i5-3210M 2.5Ghz) was easily, Careful with the screws, use screwdriver fitting exactly with the screws, you damage them very fast. Work very exactly, relaxed with time, consentration, good Tools and with feelings in your hands. Disconnect the Akku was easy if you take care, remove it to be safe, Two screws more, more space to work & haven`t to think about damaging someting. Apple use diffrent screws, you should have many difffrent scewdrivers. It is also good to clean everything inside, With time everything gets very dusty & dirty, don`t forget the sides and little fittings at the case. Use a pinsel, alcohol, soft peace stuff, it will look like new. If you have knowledge & experience, you can paint it in any colour or airbrushing for individualizing. You can also just polish it with a soft Politure (Sonax car Polish No1, NOT with wax or take an other light Politure you familiar & can do the job, A Laptop should serviced once a year, keeping it good working over years
First thing i do is open & cleanig everything inside,specially the cooling & fan, renew the thermal paste with an high quality product. Install the Nain System, clean up Bloatware and other unnecessary things, install standard software for daily use, additional change system components against better one (Edge to Firefox, Windows Media Player to VLC , an Office Suite and configuring everything for Data Protection, Privacy- & Indentety Protection, install Drivers from the component Manufactur (incedible effect, disable limitations, more functions, work better & faster, increasing performance, additional change the WiFi & Bluetooth Card to a better one a UMTS WWAN to an LTE Card, increase RAM with two Dual-Channel working SODIMMs, Use M2 or 2,5" SSD if no M2 Slot aviable) as System- and Software iDrive, a FAT32 formatted 32GB Partition to be safe of metaviruses comes with harmless downloads, and a big 2,5 HDD to store the user data. What does you guys think about this? Old Computer become a new life,
I livein Austria, near Vienna, if someone needs help or anything else, i would be glad to help. I always searching old or broken devices to bring them to new live. I also searching for spare parts, specilly a Bottom & Side Case and a 256GB or higher NGFF Storage Card for a Sony Vaio Tab 11 SVT1144HE (2014), some 14,1" Displays for a HP Probook 440G5 (2016), Elitebook MT 43 Mobile Thin Client, (2011), Dell Vostro 3460 (2012) Lenovo Thinkpad T440s (2014), and a Logic Board for an Lenovo Ideapad 330-15ARR (2017, damaged by Water i think) and a Logic Bord for an Alienware 17R4 with i7-6870HX & Nvidia 1080 (2018, CPU dead, maybe there is a repair Guide or workaround to bring it back to Life). I need always 8GB or 16GB DDR3 and DDR4 RAM Storage (perfectly two ident one for Dual-Channel use for Laptops, M2 SATA 6GB/s and NVMe PCIe SSDs 500GB or more and 2,5"SSD or HDD with 1TB or more and 3,5" HDD with 4GB or above. If you have some of this or other useful parts and doesn`t need them, please make me an offer, maybe
2
an change something you need. This is not a Business what i do, it`s more a Hobby with challenging new Excercices.. Thats the best Point. Plase forgive me as a Newbie this very long Post in the wrong Section, but if you are start writing you cannot stop.... But now i have to come to an end and would be happy if someone wants to get in contact. My E-Mail is: udontknowme@gmx.at (the adress name is just a notice against Big Data and for Privacy Protection!
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
Carefully pull the camera cable out of its socket on the logic board.
My cable is broken, have the part number or code to buy?
I found there was plenty of length in the camera cable (as it goes around two sides of the optical drive) so does not need to be disconnected - just ease it out of the slot alongside the drive and lay it diagonally across.
Carefully move the AirPort/Bluetooth ribbon cable out of the way as you peel the camera cable off the adhesive securing it to the subwoofer and the AirPort/Bluetooth bracket.
De-route the camera cable out from under the retaining finger molded into the AirPort/Bluetooth bracket.
Using the method described in the last step, disconnect the remaining three antenna connectors.
De-route their cables from the slots cut in the AirPort/Bluetooth bracket.
I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
Actually, on my repair attempt, one antenna cable broke (on the image the bottom right one in the red square), I’m not sure whether it broke already before or was morbid somehow. Fact is. suddenly I had this cable in my fingers, and was sure I completely broke the macbook and need to find a new display now.
But as it turned out: the Mac is still fully working, including WIFI, BT, Camera etc. So apart from my huge relief, I want to address that these cables may break easily at their connection with the display. And that one antenna might be not mandatory for WIFI to work.
How do I know which of these cables goes in which slot when attaching the new display?
BellaVulpa - 回复
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
Use the tip of a spudger to lift the AirPort/Bluetooth cable connector out of its socket on the AirPort/Bluetooth board.
Remove the AirPort/Bluetooth cable.
Hi, any one know the name or the number part of the female connector of the flex cable? (the one on the card)
Remove the AirPort/Bluetooth board from its bracket.
Why doesn't the replacement bracket come with a thermal pad, or maybe I didn't see a hint to buy one too?
Why doesn't the bracket come with a thermal pad or a hint to buy one?
92等其他人完成本指南。
12条评论
Just to say if you only need to replace the cable the from the main logic to the Airport card it is very simple after battery disconnect its just pry up logic board connector carefully then peel back tape at airport card and remove cable.
Thats all there is to the cable replacement and it fixed my No wifi hardware found and intermittent wifi which it would seem is a common fault As always a great guide thank you.
Thanks for the tip Keith. I did the cable replacement too based on your comment, and it worked for me. Worth trying before swapping teh whole assembly.
My macbook pro 13 2014 version wifi screen holder and the wifi card bluetooth cables are broken , so i went to repair it by my self and i bought the wrong full screen and the wifi card back to macbook pro 13 2010 version , it was shock so i would to know Can i change the wifi card cables and the screen adopted cable to the new cables of 2014 macbook pro 13 2014 version?
what's the difference between the normal "phillips screws" and the "shouldered phillips screws"?
If you look closely with the screws (my eyes needed a magnifying glass) you will see that some of them have heads that are "stepped". hard to describe in words.
perasso -
I just completed this repair successfully thanks to an excellent instruction and some help from iFixit support due to an error I made. A couple of comments that might help someone else:
1) make sure in step 15 that you TURN THE BOARD OVER and remove the tape from the bottom of the board. I "continued" removing tape from the top and then got completely confused when I couldn't find the screws in the next step. Yeah, it was my mistake because i didn't read the instructions carefully.
2) In step 15, leave the tape attached at the end of the bracket. this will make it much easier to replace the tape when reassembling.
one further comment as to whether or not you actually need to replace the board.
I was having intermittent interference problems from other nearby bluetooth enabled computers. So I checked the signal strength and it seemed low. (you can do this by holding down the option key and clicking the bluetooth symbol in the banner, then you click on the device you are interested in). My BT speaker was at -68dbm (considered low) but was at -15dbm when it was at the same distance from my macbook 1.1 (i.e. white, plastic macbook). This is a huge difference (dBm is a log scale) so I replaced the BT board.
But after I replaced the board I measured again I got the same signal strength. I then checked it with another macbook pro and again I got the same signal strength.
So intermittent BT problems and low signal strength don't necessarily mean you need to replace the board. The macbook pro just doesn't have good BT signal strength, at least not compared to the old macbooks.
Notice when you replace the airport card that there is a precaution for handling: electrostatic sensitive devices. This could be why there is an error after replacement. Read up on dangers/handling and be extra careful during cold weather.
I replaced the airport card in my Mac following this instruction. At first, it seemed to work fine. Now, it is deactivated every now and then and I am not able to activate it again. As of now, a reboot seems to help but that’s not really a solution. Can someone help me?
Can this BT be upgraded from 4.0 to 5.0?
Sorry no ;-{
BroadCom stopped making the Combo board Apple was using. Note the connector to the logic board is on the face. The next generation uses an edge connector system and there is no means to upgrade to it.
The only way is to find a USB-A BT 5.0 dongle
Dan -
This totally fixed my Wifi/Bluetooth issue. Professionals at a certified apple repair shop told me the repair is to expensive , complicated and not worth it I should just buy a USB WIFI stick… so I replaced the airport board and the WIFI cable myself with help of this instruction, in the end it turned out that the board was fine (old board is back inside) and I only had a broken WIFI cable. Total cost 8,40€ WIFI board and 6,18€ for the cable, less than an annoying WLAN stick that doesn’t even support BT. Thanks a lot to the author!
How much weight can I save by removing the optical drive?
gunes314 - 回复
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - 回复
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - 回复
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - 回复
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
We have a guide for that!
如何卸下滑丝的螺丝
Sam Omiotek -
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - 回复
A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
Iain Boyd - 回复
I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
cam2000deluxe -
Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
Patrick Langvardt - 回复
That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
Gary Register -
Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
Degeorges - 回复
Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
Claire Miesch -
Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
Moritz - 回复
Funny, it's not her hands that are doing the close ups. :)
Cinemated Man - 回复
What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
MLNLRD - 回复
