跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
MacBook Pro 13" Unibody 中期 2010 光驱更换
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 13" Unibody 中期 2010 光驱更换, 光驱: 步骤 1 中的图像 1,1
    • 为了预防危险,我们建议您将低音扬声器连接器与逻辑板断开连接,以避免放电。 此步骤是可选的,不强求。
    • 卸下可能在上面的软衬垫,然后将连接器从逻辑板上的插座上轻轻拉出。
    It is not necessary to remove the camera cable connector (step 5) or the camera cable connector (step 10). Simply push the camera cable gently aside to remove one of the three screws securing the optical drive (step 11). Gently wiggle the optical drive from under the camera cable connector and go to step 12. Less chance of ruining your motherboard!
    tomhart - 回复
    Absolutely. Leave it alone, you don’t need to run the risks of removing this cable, I did the replacement fine without it
    Steven Taylor -
    It does indeed come out of the connector, but the picture makes it hard to see how; the connector it goes into sits on top of the board—however, I, too, ripped mine off the board trying to remove it; I only got it out of the clip after I tore it off. SIMPLY DONT; it's unnecessary. I plan to solder it back if one of my Robotics club friends lets me borrow a soldering iron.
    Rachel - 回复
    Alors je déconseille très fortement de toucher ce connecteur, il est extrêmement fragile. De plus, cela n’a pas d’incidence sur la suite des opérations
    Laskoni - 回复
    The author needs to go back through this guide and correct lots of order mistakes. The fan was removed in steps 3-5 yet it’s still being shown installed in steps 19-22.
    plink53 - 回复
    The 4-pin push connector for the sub-woofer is near impossible to reconnect
    It mates with a female connector that sits on top of 4 tiny solder points (it's held on by a spot of glue, I believe), and when applying ANY pressure to connect, the side clip(s) will snap off. Then the connector itself will become unglued. It would be simple enough to connect the 2 parts, then place a drop of glue on the logic board after positioning it above the solder points, but the female connector broke apart in my hand. So now screwed, with no way to connect sub/ R speaker without installing another logic board. Fan connector looks to be exactly the same
    Peter Watkins - 回复
  2. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 2 中的图像 1,1
    • 在断开相机电缆之前,必须将粘贴到逻辑板上的小透明塑料电缆固定器(红色框)滑出。 当您将其从相机电缆连接器上滑开时,请小心不要将板上的任何组件断开。
    • 将相机电缆连接器朝向光驱驱动器拉动,以将其与逻辑板断开连接。
    • 这个插座是金属的,容易弯曲。 在重新连接两者之前,请确保将连接器与逻辑板上的插座对齐。
    I just completed this replacement and there is no need to do this step, you can work around this cable pretty easily. Obviously you need to be careful "dancing" around it. But it's perfectly feasible and you don't risk to break stuff disconnecting it.
    Massimo C - 回复
  3. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 3 中的图像 1,1
    • 使用撬棒扁平一端来径直从逻辑板上撬起光驱连接头。
  4. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 4 中的图像 1,1
    • 使用撬棒径直从逻辑板上撬起硬盘连接头。
  5. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 5 中的图像 1,1
    • 移除将低音扬声器与顶壳固定的螺丝。
    • 一颗3.8mm 十字螺丝。
    • 一颗5mm 十字螺丝。
    On my computer, the 3.8 mm screw was near the midpoint of the subwoofer (left-to-right in the photo) and near the bottom. The 5 mm screw was top right of the subwoofer.
    BobG - 回复
  6. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 6 中的图像 1,2 MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 6 中的图像 2,2
    • 低音扬声器仍然与右扬声器连接,所以请不要完全将其移走。
    • 从光驱上提起低音扬声器,将其放在电脑一边。
  7. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 7 中的图像 1,2 MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 7 中的图像 2,2
    • 移除两颗将相机线缆支架固定到顶壳的10mm十字螺丝。
    • 最左侧的螺丝可能会一直在支架上呆着。
    • 将相机线缆支架从顶盖中取出。
  8. MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 8 中的图像 1,2 MacBook Pro 13" Unibody 中期 2010 光驱更换: 步骤 8 中的图像 2,2
    • 移除三颗将光驱与顶壳固定的2.5mm十字螺丝。
    • 从光驱右边提起光驱然后将其从电脑中拉出。
    Install 2 outside screws first and then single inside screw to allow wiggle room to get outside screws in. Do not tighten screws until all are started.
    JASON CULP - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
另外一个人完成了本指南。
由衷感谢以下译者:
en zh
81%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
一条评论
Bonsoir. Le tuto est très clair, mais je voudrais savoir s’il est applicable sur la version 15” du MBP 10. Amicalement, Marc.
Marc Blériot - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 688
