简介
Use this guide to replace the MagSafe DC-in board.
你所需要的
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Gently pull the display data cable connector away parallel to the board.
Disconnect the DC-In board by pulling its connector away from the socket on the logic board.
84等其他人完成本指南。
4指南评论
The Tri-wing Y1screwdriver suggested for this procedure is too big for the removal of the battery screws. I completed replacing the DC in board without removing the battery.
I have just tested several of those drivers from our shelf in 3 different MacBooks we have here with tri-wing type screws, and they are all a perfect fit. I have sent you an email to try and find out why your driver did not fit, you may have a mid 2009 model with pentalobular screws instead?
Thanks! Guide was wonderful! I wish there had been a bit more information about the proper routing of the dc-in cable as the first time I put it back together I accidentally routed the cable on the outside of the mother board riser which made it impossible to seat the display cable hold down clamp properly. I had to re-remove the main board in order to get the dc-in cable on the other side of the riser. Not a biggie, but a note on that step would be helpful. Thanks again!!
So I switched it out, but in the process ripped the battery indicator cable connector, and now the wifi doesn’t work either… it’s super slow to start up. Any suggestions for fixes?
