本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a cosmetically damaged clutch cover.
你所需要的
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
Disconnect the camera cable by sliding it horizontally out of its socket.
If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
Grab the clutch cover as shown and slide it toward the right side of the display.
39等其他人完成本指南。
5条评论
What is the circuit board under the clutch? I broke off one of the pieces putting the clutch back on.
That is the airport card and its antennae.
Is this the same process to follow for replacing a clutch cover on a MacBook Pro 13" mid-2012 model?
seanhelmes - 回复
I used this guide for my mid-2012 model (because I thought it was a 2010). It was very similar. The Torx screws were a T7 instead of a T6 and the subwoofer connects with the airport card (instead of the airport card being inside the clutch). I suspect there is a more specific guide on this site. :)
Nicely documented. It was easy to follow and the job went well. Thank you!
