跳转到主内容
MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 3 中的图像 1,1
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  5. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out of the upper case
  6. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  7. MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 7 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Trackpad Replacement: 步骤 7 中的图像 2,2
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
结论
8等其他人完成本指南。
SIMRAN
于10/30/10注册
6,363 声望
撰写一个指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,539篇指南
2条评论
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - 回复
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 19,729
