简介
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer and right speaker.
  1. Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
      • Seven 3 mm Phillips screws.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. Using the flat end of a spudger, pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
    • Using the flat end of a spudger, pry the right speaker/subwoofer cable connector straight up off the logic board. Be careful not to lift the socket. Pull the connector toward the optical drive.
    • Pry up from beneath the wires.
  5. It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  6. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  7. Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  8. Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  9. Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
    • Remove the two Phillips screws securing the subwoofer to the upper case. The right one is 5 mm and the left 3.9 mm.
    • The longer of the two screws is on the right.
  10. The subwoofer is still connected to the right speaker, so don't completely remove it just yet. Lift the subwoofer off the optical drive, and set it above the computer.
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  11. Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case. The right screw may remain captive in the camera cable.
    • Remove the two 8.4 mm Phillips screws securing the camera cable bracket to the upper case.
    • The right screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  12. Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case. Lift the optical drive from its right edge and pull it out of the computer.
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
  13. Peel back the small piece of black tape covering the right speaker cable.
    • Peel back the small piece of black tape covering the right speaker cable.
    • Be careful, as the power button ribbon cable is directly under this piece of tape.
  14. Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
    • Use the tip of a spudger to pry the right speaker up off the adhesive securing it to the upper case.
  15. Lift the subwoofer and right speaker assembly out of the upper case.
    • Lift the subwoofer and right speaker assembly out of the upper case.
结论
29等其他人完成本指南。
Thanks ifixit for the super guide. I followed the steps and now my mac works properly again!
Toni - 回复
Thank you iFixit!
I too snapped the right speaker/subwoofer cable connector right off the mother board, but with patience and a little research, I learned how to solder the thing back on. How about a Warning!!!!! inserted at that step.? I only saw that there were comments AFTER I gingerly tried to pry the connector as instructed. It would help to show how the parts fit together as is done with the fan cable connector. Those instructions (the fan cable connector instructions), helped me better understand what I was prying apart and gave me an idea of how best to do it, and how the speaker/subwoofer cable connector connected to the board, as well as how to position the “pads.”
So, I learned from my mistake, which is a good thing. Nonetheless, I would have preferred to learn BEFORE I snapped off the cable connector, LOL!
Thanks Again for this incredible site.
Leslie L. Gordon - 回复
浏览统计数据:
过去的24小时: 13
过去的7天: 70
过去的30天: 276
总计 40,694
