本指南有最近更改,您可查看未经巡查的最新版本。
简介
Restore balanced sound to your laptop by replacing the left speaker.
你所需要的
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Grab the plastic pull tab secured to the display data cable lock, and rotate it toward the DC-in side of the computer.
Pull the display data cable connector straight away from its socket, towards the DC-in side of the computer.
9等其他人完成本指南。
2条评论
Hallo Olga, dieses MacBook hat die Nummer A 1278.
