跳转到主内容
MacBook Pro 13" Unibody Early 2011 Lower Case Replacement
你所需要的
  1. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: 步骤 2 中的图像 1,2 MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
结论
60等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 13
过去 30 天: 48
总计 35,900
