本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to completely replace the logic board.
你所需要的
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
De-route the microphone cable from its slot molded into the left speaker enclosure.
129等其他人完成本指南。
6条评论
My son spilled soda into 13"MB early 2011, I did not get to repair for 6 weeks. Machine took over twice typical time to start-up and once running, cursor showed stuttered movement and launching applications was very slow.
I used guide (only steps 1-19) to remove logic board and delicately cleaned with very slightly damp Q-Tip (using Windex electronics cleaner) & dried, every place I cleaned, using compressed air. I did not remove the heatsink, as I assumed the paste protected the processor underneath.
Once cleaned, I reversed all steps and it booted quickly and all other issues disappeared. THANK YOU!!!
what is logic board part number if I want to order new one
For the Early 2011 MBP A1278 with the Core i5 2.3 GHz processor, the part numbers are 661-5869 and 661-6078
Susanna -
Do you send to Brazil the same Logic board above Its the Early 2011 MBP A1278 with the Core i5 2.3 GHz processo. It had many issues with it’s Logic boar and I think it’s a manufacture defect. I’m so desaposentes with apple planned Obsolescence, ando no repair. It’s not the same apple. My computer was boutique inAustralia , so I’m protected by their consumer act(2010) I just have to prove it was a hidden problem.
My track pad was difficult to "click". I've replaced batteries before, so I knew that it was definitely a swollen battery. However, when removing the damaged, swollen battery, I used the end of a flat head screw driver to pry up the battery connection... DON'T DO THAT! I saw the tiniest of sparks around pins 4-5-6 on the 9 pin battery connector. New battery installed, but the OS didn't recognize the new battery -- black "X" over the battery indicator. Further, the wall charger would not recharge the new battery. Instead, the computer ran off the 30% charge that new batteries are shipped with. I ordered another new battery, and after draining a second battery without being able to charge, I figured that spark was the sign that I fried something in the logic board. Indeed that was exactly the case, and logic board replacement did fix the issue. I found these instructions INVALUABLE in replacing my old logic board.
$260 lesson: Always use a plastic spudger when dislodging connectors in computers!
Thanks!
