跳转到主内容
MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws will remain attached to the hard drive bracket.
  2. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the hard drive bracket.
    • The hard drive bracket may be firmly seated against the upper case.
  3. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Use the attached pull tab to lift the hard drive out of the upper case.
    • Don't try to completely remove the hard drive just yet. It is still attached to the hard drive cable.
  4. MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: 步骤 4 中的图像 1,2 MacBook Pro 13" Unibody Early 2011 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Pull the hard drive cable away from the body of the hard drive.
    • Remove the hard drive.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,336
