跳转到主内容
MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement
你所需要的
  1. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 2 中的图像 1,2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement, Battery Connection: 步骤 3 中的图像 1,2 MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement, Battery Connection: 步骤 3 中的图像 2,2
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
  4. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 4 中的图像 1,1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement, AirPort/Bluetooth Cable: 步骤 5 中的图像 1,1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
  6. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 6 中的图像 1,1
    • Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector above the optical drive.
  7. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 7 中的图像 1,1
    • Use the tip of a spudger to lift the AirPort/Bluetooth connector off of its socket on the AirPort/Bluetooth board.
  8. MacBook Pro 13" Unibody Early 2011 AirPort/Bluetooth Cable Replacement: 步骤 8 中的图像 1,1
    • Remove the AirPort/Bluetooth cable from the machine.
结论
24等其他人完成本指南。
3条评论
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable!
Michael Schwern - 回复
This specific cable or the one that goes up to the screen?
Anton Wretman SSIS -
Yes, this cable.
Michael Schwern -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 35
总计 29,654
