跳转到主内容
MacBook Pro 13" Unibody 中期 2010 电池更换
你所需要的
  1. MacBook Pro 13" Unibody 中期 2010 电池更换, 后壳: 步骤 1 中的图像 1,1
    • 移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
    • 7个3 mm Phillips螺丝
    • 3个13.5 mm Phillips 螺丝
  2. MacBook Pro 13" Unibody 中期 2010 电池更换: 步骤 2 中的图像 1,1
    • 轻轻提起后壳然后推向电脑的后方来松开卡舌。
  3. MacBook Pro 13" Unibody 中期 2010 电池更换, 电池: 步骤 3 中的图像 1,1
    • 拆下将电池固定在顶壳的三点螺丝。
    • 1个 5.5 mm 三点螺丝。
    • 1个13.5 mm 三点螺丝
  4. MacBook Pro 13" Unibody 中期 2010 电池更换: 步骤 4 中的图像 1,1
    • 使用撬棒扁平的一段来将电池的连接器从逻辑板的插座中分离开来。
  5. MacBook Pro 13" Unibody 中期 2010 电池更换: 步骤 5 中的图像 1,1
    • 将电池从顶壳中移除。
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
683等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
26条评论
You guys are awesome! My granddaughter spilled a whole coke on the Mac and it went fizz! After some weeks I took it to the Apple store where it was declared it dead. They offered me a refurbished machine for $800, but insteaed I came home, took the disk out and hooked it via a USB carrier to another Mac which proved that the disk had not been harmed. I put it back in the machine and booted up at which point it became obvious that the battery was dead. One pass at Google turned up IFixIt where I found the battery and the correct, goofy tri-point screwdriver. The battery arrived a bit ago and the Mac is up and running as if nothing happened . . . a tidy savings of $650!
Thanks so much1
amzbay - 回复
This was a total life saver! A few weeks ago my house was hit by lightning and even though my computer wasn't plugged in (thank God!) my charger was completely fried. I ordered a new charger but my computer still wasn't working- Apple said my computer was done for. A friend said it was probably my battery and told me about ifixit.com. I was able to buy a new battery and change it myself (it was so easy!!!). Saved me from spending a bunch of $$ at the Apple store. I move out of the Country in a few weeks and didn't know what I was going to do without a computer. Thanks ifixit!!!
talithab - 回复
When I followed this exactly, I booted up my MacBook to see that my battery had an x through it with the no battery availible popping up when I scrolled over it. I (stupidly) left the computer on while I browsed for a solution. The whole time my charger showed a green light. Suddenly the computer turned off and hasn't been able to be turned back on since despite switching to another battery and another charger. The charger still shows a green light, which means the battery is either fully charged or installed incorrectly. I don't understand how it can be installed incorrectly when the only part to put it into the computer is the plug in. Please someone help me, I have no idea how to fix it and have made multiple forums on here asking for help, to no avail.
Jack Roche - 回复
I think you are SOL. I had same problem a few days ago. I have attempted everything I could find from online resources. Bottom Line: ship it to an Apple authorized repair shop or an Apple Store. Battery replacement Cost is now only $130, which isn't much more than iFixIt cost.
gkofga -
Your connector or socket may have broken. Open the Mac and check if you missed something.
TheYootz Media Group -
添加评论
浏览统计数据:
过去 24 小时: 26
过去 7 天: 169
过去 30 天: 821
总计 606,940
