跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
MacBook Pro 13" Unibody 中期 2009 电池更换
你所需要的
  1. MacBook Pro 13" Unibody 中期 2009 电池更换, 后壳: 步骤 1 中的图像 1,1
    • 移除下列将 MacBook Pro 13" Unibody后壳固定的 10个 螺丝:
    • 7个3 mm Phillips螺丝
    • 3个13.5 mm Phillips 螺丝
  2. MacBook Pro 13" Unibody 中期 2009 电池更换: 步骤 2 中的图像 1,1
    • 轻轻提起后壳然后推向电脑的后方来松开卡舌。
  3. MacBook Pro 13" Unibody 中期 2009 电池更换, 电池: 步骤 3 中的图像 1,1
    • 拆下将电池固定在顶壳的三点螺丝。
    • 1个 5.5 mm 三点螺丝。
    • 1个13.5 mm 三点螺丝
  4. MacBook Pro 13" Unibody 中期 2009 电池更换: 步骤 4 中的图像 1,1
    • 使用撬棒扁平的一段来将电池的连接器从逻辑板的插座中分离开来。
  5. MacBook Pro 13" Unibody 中期 2009 电池更换: 步骤 5 中的图像 1,1
    • 将电池从顶壳中移除。
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
727等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
50条评论
My laptop wouldn't believe the battery was new until I reset the SMC as well ( http://support.apple.com/kb/HT3964 ).
penguinofdeath - 回复
Perfect! I didn't want to wait for the Tri-wing screwdriver to ship, so I gave it a try by wedging a FH 1 in between two of the wings. It worked well to unscrew, but you must be very careful when resetting the screws that hold the battery. If you get them started with your finger (a little pressure with your thumb pushing straight down will get the job done) then you can do a few final turns with the FH 1. If you try to start resetting the screws with the off-center-FH1-workaround, you will strip the screw! Keep the screws centered and don't force anything.
Laurence Benson - 回复
worked like a charm. my old battery had bulged and made it so that the track pad would not click :-( replacing the battery did the trick.
statprof - 回复
My local Apple Store wants $179 plus tax to change this battery, AND I have to leave my laptop for "a couple of days." This is one store that clearly doesn't get it (Cherry Creak Mall, Denver). Thus, a DIY fix is mandatory... but, they won't sell just the battery.
channonholiday - 回复
iFixit sells the battery you need for $119 ([关联产品丢失或禁用: IF163-019]), and once you get it, doing the replacement shouldn't take more than 30 minutes, even if you've never done a repair like this before.
Taylor Arnicar -
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 122
过去 30 天: 642
总计 572,129
