简介
如果你的触控板有问题,或者需要移除以方便使用电池,请遵循本指南。
在你开始这个程序之前,“为了你的安全,放掉你的MacBook Pro电池。”一个充满电的锂电池如果意外被刺破,可能会引起危险的、无法控制的火灾。
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
准备一个 iOpener 并把它放在触控板带电缆的顶部大约一分钟,以软化粘合剂固定触控板带电缆到电池顶部。
如果你没有iOpener,用吹风机加热电缆代替。电缆应该是温暖的,但不要太热触摸。小心不要使电池过热。
请按逆序重组你的设备。
请按逆序重组你的设备。
4等其他人完成本指南。
由衷感谢以下译者:
94%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Great guide. Thanks for posting. One thing it assumes however, is that the replacement trackpad you’re using came with a data cable (i.e. there is no Step 23 regarding removing the data cable from the old trackpad and re-using it). I’m not sure if it’s always been this way, but the replacement trackpads iFixit sells now for this laptop do not come with a data cable. I had to re-use the data cable from the old trackpad. It wasn’t too difficult to pull the cable up and out of the connector on the old trackpad, and there is no locking tab or anything to flip up to remove it. But it was hard to get the cable back into the connector on the new trackpad with the left over adhesive and the angle of the connector. I was able to get it connected after a few careful attempts, and the trackpad works after re-assembly. Maybe in the past, the replacement trackpads iFixit sold came with a new data cable attached, but it’s worth noting that they currently do not, and you have to supply one.
Actually, the grey bar is a locking tab-the cable might work if you just pull it/shove it in, but do yourself a favor and flip it up with a spudger like other locking tabs. I tried shoving it but neither the touchpad or keyboard worked when i did that
Spider -
