跳转到主内容
修复你的物品
维修的权力
商店
简介
Prerequisite only—remove the logic board and heat sink together as a single assembly, either for further disassembly or simply to get it out of the way.
  1. Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket. Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket.
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the keyboard connector bracket.
  2. Remove the keyboard connector bracket.
    • Remove the keyboard connector bracket.
  3. Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board. Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board.
    • Use a spudger to disconnect the keyboard connector by prying it straight up from the logic board.
  4. Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable. Remove the cover.
    • Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
    • Remove the cover.
  5. Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector. Remove the cover.
    • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
    • Remove the cover.
  6. Pry the display board flex cable straight up from its socket to disconnect it from the display board. Pry the display board flex cable straight up from its socket to disconnect it from the display board.
    • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
  7. Using a T3 Torx driver: Remove two 1.4 mm screws from the Thunderbolt port connector bracket on the left.
    • Using a T3 Torx driver:
    • Remove two 1.4 mm screws from the Thunderbolt port connector bracket on the left.
    • Remove two more 1.4 mm screws from the Thunderbolt port connector bracket on the right.
  8. Use a spudger to disconnect the left-side Thunderbolt port connector by prying it straight up from the logic board. Pry from the inside edge, nearest the fan. Gently push the connector aside so it won't interfere with logic board removal.
    • Use a spudger to disconnect the left-side Thunderbolt port connector by prying it straight up from the logic board.
    • Pry from the inside edge, nearest the fan.
    • Gently push the connector aside so it won't interfere with logic board removal.
  9. Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside. Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside. Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside.
    • Repeat for the right-side Thunderbolt port connector, prying it up from the inside edge and pushing it carefully aside.
  10. Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors. Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors.
    • Use a T3 Torx driver to remove the two 1.9 mm screws from the cover bracket securing the Touch ID and 3.5 mm audio jack connectors.
  11. Remove the bracket.
    • Remove the bracket.
  12. Use a spudger to disconnect the 3.5 mm audio jack flex cable by prying it straight up from the logic board. Gently push the flex cable aside. Gently push the flex cable aside.
    • Use a spudger to disconnect the 3.5 mm audio jack flex cable by prying it straight up from the logic board.
    • Gently push the flex cable aside.
  13. Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board. Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board.
    • Disconnect the Touch ID and power button flex cable by prying it straight up from the logic board.
  14. Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable. Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable.
    • Apply mild heat using an iOpener, heat gun, or hair dryer to soften the adhesive under the power button/Touch ID flex cable.
  15. Carefully slide an opening pick under the flex cable to separate it from the logic board, and push it carefully aside. Be very careful not to damage this delicate flex cable. The attached Touch ID sensor is uniquely paired to your MacBook's logic board—if damaged, only Apple can successfully replace it. If you have trouble, don't force it—apply a little more heat and try again.
    • Carefully slide an opening pick under the flex cable to separate it from the logic board, and push it carefully aside.
    • Be very careful not to damage this delicate flex cable. The attached Touch ID sensor is uniquely paired to your MacBook's logic board—if damaged, only Apple can successfully replace it.
    • If you have trouble, don't force it—apply a little more heat and try again.
  16. Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket. Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket.
    • Use a T3 Torx driver to remove the 1.9 mm screw from the Touch Bar digitizer connector bracket.
  17. Remove the bracket.
  18. Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board. Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board.
    • Use a spudger to disconnect the Touch Bar digitizer by prying its connector straight up from the logic board.
  19. Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket. Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket.
    • Use a T3 Torx driver to remove two 1.9 mm screws from the Touch Bar display connector bracket.
  20. Remove the bracket.
  21. Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board. Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board.
    • Use a spudger to disconnect the Touch Bar display connector by prying it straight up from the logic board.
  22. Peel back any tape covering the microphone connector socket. Peel back any tape covering the microphone connector socket.
    • Peel back any tape covering the microphone connector socket.
  23. Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board. Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
    • Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
  24. Disconnect the microphone cable by pulling it back—away from the fan—until it slides out of its socket. If possible, pull on the attached tape, rather than on the cable itself.
    • Disconnect the microphone cable by pulling it back—away from the fan—until it slides out of its socket.
    • If possible, pull on the attached tape, rather than on the cable itself.
  25. Peel back any tape covering the connector for the left-side tweeter. Peel back any tape covering the connector for the left-side tweeter.
    • Peel back any tape covering the connector for the left-side tweeter.
  26. Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board. Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board.
    • Flip open the locking flap for the left-side tweeter ZIF connector by prying it straight up from the logic board.
  27. Disconnect the cable by pulling it towards the tweeter until it slides out of its socket. If possible, pull on the attached tape rather than the cable itself.
    • Disconnect the cable by pulling it towards the tweeter until it slides out of its socket.
    • If possible, pull on the attached tape rather than the cable itself.
  28. Underneath the tweeter's flex cable lies a second ZIF connector, for the left main speaker. Peel back any tape covering the socket for the left main speaker.
    • Underneath the tweeter's flex cable lies a second ZIF connector, for the left main speaker.
    • Peel back any tape covering the socket for the left main speaker.
  29. Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board. Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board.
    • Flip open the locking flap for the left main speaker ZIF connector by prying it straight up from the logic board.
  30. Disconnect the left main speaker cable by pulling it toward the tweeter until it slides free from its socket. Remember to pull on the attached tape, not the cable.
    • Disconnect the left main speaker cable by pulling it toward the tweeter until it slides free from its socket.
    • Remember to pull on the attached tape, not the cable.
  31. Repeat the previous six steps to disconnect the opposite tweeter and main speaker, on the right. Begin by peeling back any tape covering the tweeter connector.
    • Repeat the previous six steps to disconnect the opposite tweeter and main speaker, on the right.
    • Begin by peeling back any tape covering the tweeter connector.
  32. Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board. Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board.
    • Flip open the locking flap for the right-side tweeter ZIF connector by prying it straight up from the logic board.
  33. Disconnect the cable by pulling it towards the tweeter until it slides out of its socket. Remember to pull on the tape if possible—not the actual cable.
    • Remember to pull on the tape if possible—not the actual cable.
  34. Peel back any tape covering the connector for the right-side main speaker. Peel back any tape covering the connector for the right-side main speaker.
    • Peel back any tape covering the connector for the right-side main speaker.
  35. Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board. Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board.
    • Flip open the locking flap for the right-side main speaker ZIF connector by prying it straight up from the logic board.
  36. Pull the right-side main speaker cable toward the tweeter until it slides free from its socket.
    • Pull the right-side main speaker cable toward the tweeter until it slides free from its socket.
  37. Disconnect the first antenna cable by prying it straight up from its socket. Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it. Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
    • Disconnect the first antenna cable by prying it straight up from its socket.
    • Carefully slide your tweezers or the flat end of your spudger underneath the cable until it's near the socket, and then gently twist or pry up to disconnect it.
  38. Repeat the previous step to disconnect the two remaining antenna cables.
    • Repeat the previous step to disconnect the two remaining antenna cables.
    • To reconnect each cable, align the connector directly over its socket, and then press down to snap it into place.
  39. Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle. Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle.
    • Use a T5 Torx driver to remove the 2.9 mm screw securing the antenna cable bundle.
  40. Remove all ten screws securing the logic board assembly: Three 2.5 mm Torx T3 screws
    • Remove all ten screws securing the logic board assembly:
    • Three 2.5 mm Torx T3 screws
    • Five 2.9 mm Torx T5 screws
    • Two 3.0 mm Torx T5 screws
    • During reassembly, install these screws loosely and adjust the logic board's position if necessary before tightening the screws.
  41. Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans. If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate. If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
    • Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
    • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
  42. The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly. There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
    • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
    • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
    • Lift from the left side to remove the logic board assembly.
  43. When reinstalling the logic board assembly: Check the alignment of the rubber vibration dampers, and adjust them as needed. Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • When reinstalling the logic board assembly:
    • Check the alignment of the rubber vibration dampers, and adjust them as needed.
    • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
    • Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
结论
Jeff Suovanen
于2013年08月06日注册
344,463 信誉积分
创作了257篇指南
团队
iFixit iFixit 的会员
Community
134 名成员
创作了15,565篇指南
Microphoneのパーツの説明欄には、Teardownの動画がリンクされていますが、その動画にはMic部分の説明が無いため、このページをリンクしておくと良いと思いました。
This page should be linked In the page of microphone assembly. Threre is not any microphone assembly part in the video embedded in the page.
polo - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 174
