简介
使用本指南来更换2016后期带Touch Bar的13寸MacBook Pro 显示屏组件。
在开始此过程之前,你可能需要与苹果确认是否符合免费维修的条件。如果显示器的背光灯停止工作,或者显示器在屏幕的整个底部显示垂直明亮的区域(也称为“舞台灯”),则MacBook Pro可能符合苹果的显示背光服务程序。
``为了安全起见,请在维修之前将MacBook Pro的电池电量消耗低于25%。''
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
抓住显示屏电缆组件的左侧,将其拉向MacBook的底端,然后远离弹簧铰链。
使用一把镊子将显示器电缆的弹簧铰链从支架中拉出。
重复此步骤,移除显示器电缆组件的右弹簧铰链
这个步骤还没有翻译 帮忙翻译一下
Free the right hinge and remove the screen.
Make sure the screen hinges are fully open and guide them into their recesses in the frame.
Partially tighten the six hinge screws.
Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
Fully tighten the hinge screws.
将新的替换零件与原始零件进行比较 -- 在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
'''要重新组装设备,请按逆序执行上述步骤。
'将你的电子垃圾带到R2或e-Stewards认证回收商。
77等其他人完成本指南。
由衷感谢以下译者:
37%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
29条评论
Hello Lucas Zhu,
the interior build of the A1708 model is a bit different to this one. Especially the connection of the battery. You can check our guides for the A1708 model for the disconnection procedure. The removal of the display in general, is more or less the same with a few differences (e.g. two instead of 3 coax cables). Although the A1708 is a different model you might be able to remove the display following this guide.
THANK YOU THANK YOU THANK YOU!! You made my life so much easier. This guide was thorough and definitely made things a lot easier to understand.
Thanks for the guide! I’ve completed mine around 1 1/2 hours while being really careful not to short-circuit any components. Other video that I used for reference: https://youtu.be/153tVLIZVm8 and https://youtu.be/bEDhEWLrkUs
