跳转到主内容
修复你的物品
维修的权力
商店
已存档
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
已存档
简介
Where to go to locate image files responsible for Mission control and dashboard backgrounds. Then I will show you HOW TO SAFELY AND PROPERLY CHANGE THEM!
  1. As Always: Be Careful. The Files around what you are working with ARE VITAL TO YOU Operating SYSTEM and IT's UI! As Always: Be Careful. The Files around what you are working with ARE VITAL TO YOU Operating SYSTEM and IT's UI!
    • As Always: Be Careful. The Files around what you are working with ARE VITAL TO YOU Operating SYSTEM and IT's UI!
    • Open up Finder.
    • Navigate to your System Hard Drive (ie: Mine is "Macintosh HD")
    • Open "SYSTEM"
    • Open "LIBRARY"
    • Open "CORE SERVICES"
    • NOW BE CAREFUL Some of these Apps are important! Find the app "DOCK.APP" open the menu (right click/two finger click) and click "SHOW PACKAGE CONTENTS"
    • Open "CONTENTS"
    • AGAIN BE CAREFUL HERE!!! Open "RESOURCES"
  2. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  3. The Files within this folder are very important for part of your Mac's GUI; So Only mess with the following files mentioned!
    • The Files within this folder are very important for part of your Mac's GUI; So Only mess with the following files mentioned!
    • "PIRELLI.png" & PIRELLI@2... These files are responsible for you dashboard background and Mission Control Tab for Dashboard(if enabled)
    • There is a set Tiling mode in the OS so selecting an image of proper size is crucial.
    • Create a new folder called "pirelliORIGINAL" and place these two AND ONLY TWO files here
    • Next Take your desired Image and rename it to "pirelli.png"
    • Dimensions: I Use 2880 x1900
    • And as shown move the image to the RESOURCES FOLDER
  4. Now for Mission Control: Same steps as before instead find the files labeled "defaultdesktop.png" & " defaultdesktop@2x.png"
    • Now for Mission Control:
    • Same steps as before instead find the files labeled "defaultdesktop.png" & " defaultdesktop@2x.png"
    • put in a new folder labeled "defaultdesktopORIGINAL"
    • Chose Your Image (Make sure it is a Higher Resolution Image) and rename it to defaultdesktop.png
    • Again Drag the new image to this folder ("RESOURCES")
    • So the files are moved and in place, now to activate it...
  5. open up your terminal
    • open up your terminal
    • type the following EXACTLY (case-sensitive) killall Dock [press enter]
    • *You may need to have super user permissions for the step above. If so, add the word "sudo" before the command above. (So the whole command will read sudo killall Dock)
    • 'YOU SHOULD NOW SEE YOUR NEW BACKDROPS!""
结论
7等其他人完成本指南。
DCummuta
于2013年02月10日注册
693 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 602
