跳转到主内容
MacBook Pro 13" Software: Safe Simple Customizing Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
  1. MacBook Pro 13" Software: Safe Simple Customizing Replacement, Software: Safe Simple Customizing: 步骤 1 中的图像 1,2 MacBook Pro 13" Software: Safe Simple Customizing Replacement, Software: Safe Simple Customizing: 步骤 1 中的图像 2,2
    • As Always: Be Careful. The Files around what you are working with ARE VITAL TO YOU Operating SYSTEM and IT's UI!
    • Open up Finder.
    • Navigate to your System Hard Drive (ie: Mine is "Macintosh HD")
    • Open "SYSTEM"
    • Open "LIBRARY"
    • Open "CORE SERVICES"
    • NOW BE CAREFUL Some of these Apps are important! Find the app "DOCK.APP" open the menu (right click/two finger click) and click "SHOW PACKAGE CONTENTS"
    • Open "CONTENTS"
    • AGAIN BE CAREFUL HERE!!! Open "RESOURCES"
  2. MacBook Pro 13" Software: Safe Simple Customizing Replacement: 步骤 3 中的图像 1,1
    • The Files within this folder are very important for part of your Mac's GUI; So Only mess with the following files mentioned!
    • "PIRELLI.png" & PIRELLI@2... These files are responsible for you dashboard background and Mission Control Tab for Dashboard(if enabled)
    • There is a set Tiling mode in the OS so selecting an image of proper size is crucial.
    • Create a new folder called "pirelliORIGINAL" and place these two AND ONLY TWO files here
    • Next Take your desired Image and rename it to "pirelli.png"
    • Dimensions: I Use 2880 x1900
    • And as shown move the image to the RESOURCES FOLDER
  3. MacBook Pro 13" Software: Safe Simple Customizing Replacement: 步骤 4 中的图像 1,2 MacBook Pro 13" Software: Safe Simple Customizing Replacement: 步骤 4 中的图像 2,2
    • Now for Mission Control:
    • Same steps as before instead find the files labeled "defaultdesktop.png" & " defaultdesktop@2x.png"
    • put in a new folder labeled "defaultdesktopORIGINAL"
    • Chose Your Image (Make sure it is a Higher Resolution Image) and rename it to defaultdesktop.png
    • Again Drag the new image to this folder ("RESOURCES")
    • So the files are moved and in place, now to activate it...
  4. MacBook Pro 13" Software: Safe Simple Customizing Replacement: 步骤 5 中的图像 1,1
    • open up your terminal
    • type the following EXACTLY (case-sensitive) killall Dock [press enter]
    • *You may need to have super user permissions for the step above. If so, add the word "sudo" before the command above. (So the whole command will read sudo killall Dock)
    • 'YOU SHOULD NOW SEE YOUR NEW BACKDROPS!""
结论
7等其他人完成本指南。
DCummuta
于02/10/13注册
693 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 607
