跳转到主内容
MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement
你所需要的
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 3 中的图像 1,2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 3 中的图像 2,2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 5 中的图像 1,2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 6 中的图像 1,1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: 步骤 7 中的图像 1,2 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement, Left Speaker: 步骤 7 中的图像 2,2
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
  7. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 8 中的图像 1,1
    • Remove the following screws securing the left speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  8. MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 9 中的图像 1,3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 9 中的图像 2,3 MacBook Pro 13" Retina Display Mid 2014 Left Speaker Replacement: 步骤 9 中的图像 3,3
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
结论
35等其他人完成本指南。
Sam Goldheart
于10/18/12注册
458,568 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Community
141 名成员
创作了17,572篇指南
3条评论
참조해서 잘따라했어요~ 너무 감사해요^___^
권정철 - 回复
Youhelpme, ifixit. Done! Thx
Caue Alvarez - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 40
过去 30 天: 169
总计 21,616
