简介
Use this guide to replace a faulty MagSafe DC-In board.
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Pull in the direction of the cable, parallel to the logic board. Do not pull up.
26等其他人完成本指南。
7条评论
Thanks for great tutorial!
Yep, what are the signs of bad dc-in board?
When I plug in the charger, LED on magsafe connector doesn't light up.
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
For some reason charging doesn't start, my battery has only 600 cycles on it.
Can you guys help?
P.S. I tried plugging other adapters thats working, same thing (
Did you ever get a solution? I got a new MacBook Pro and didn’t use this one for 2 months, then went to charge it and nothing happens! No light on the charger and the battery is totally dead! I’m going to replace this DC board and maybe the battery. Did you get yours working?
I Have replaced the battery and the machine still works under the power from the new battery but the LED won’t come on the magsafe charger. Now I have replaced the DC In board and still not charging. the charger works on the other Mac in the house. What could the issue be?
