跳转到主内容
MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: 步骤 1 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement, SSD Assembly: 步骤 1 中的图像 2,2
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
  2. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 2 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 2 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 2 中的图像 3,3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  3. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the SSD assembly from the upper case.
  4. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 4 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
  5. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 5 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 5 中的图像 2,2
    • Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
    • Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
    • Only lift the SSD up far enough to grab the sides of it with your fingers. Lifting it any more may damage the card or socket.
  6. MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 SSD Assembly Replacement: 步骤 6 中的图像 2,2
    • Carefully pull the SSD straight out of its socket on the SSD tray.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 208
