当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
将固定在顶盖和背盖的螺丝卸除:
两个 2.3mm的P5五角螺丝
八个3.0mm的P5五角螺丝
22等其他人完成本指南。
5条评论
Rats:
"Wedge the tip of a spudger beneath the left speaker cable connector.
Gently pry the left speaker cable connector up off from its socket on the logic board.
Be sure you are prying up on the connector, not the socket itself."
I accidentally pried up on the socket, which looks like it was soldered to the board. Left speaker doesn't work, of course. I assume there is no fix for this, other than replacing the board??
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm. Changed both speakers as per your other guide.
timofej.se - 回复
This was great! I fixed the computer easily.
Très bon tuto. Clair et précis. Changement des 2 HP en moins d'1 heure.
Bravo à l'équipe.
