跳转到主内容
MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement
你所需要的
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  3. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  5. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  6. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  7. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  8. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Contact Board: 步骤 9 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Battery Contact Board: 步骤 9 中的图像 2,2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  9. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: 步骤 10 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: 步骤 10 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement, Left Speaker: 步骤 10 中的图像 3,3
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  10. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 11 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 11 中的图像 2,2
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  11. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 12 中的图像 1,1
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
  12. MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 13 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 Left Speaker Replacement: 步骤 13 中的图像 2,2
    • Lift and remove the left speaker out of the upper case.
结论
22等其他人完成本指南。
5条评论
Rats:
"Wedge the tip of a spudger beneath the left speaker cable connector.
Be sure you are prying up on the connector, not the socket itself."
I accidentally pried up on the socket, which looks like it was soldered to the board. Left speaker doesn't work, of course. I assume there is no fix for this, other than replacing the board??
Don Sandifer - 回复
Thank you very much for the walkthrough. No problems to follow at all. Everything worked as a charm. Changed both speakers as per your other guide.
timofej.se - 回复
I was able to follow the steps exactly as described without damaging anything. Patience is the key.
Max Max - 回复
This was great! I fixed the computer easily.
Kyle Meyers - 回复
Très bon tuto. Clair et précis. Changement des 2 HP en moins d'1 heure.
Bravo à l'équipe.
Dominique BONNEL - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 111
总计 15,718
