跳转到主内容
MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement
你所需要的
  1. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 7 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Contact Board: 步骤 9 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Battery Contact Board: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, iSight Camera Cable: 步骤 10 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, iSight Camera Cable: 步骤 10 中的图像 2,2
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  11. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 11 中的图像 1,1
    • Move the iSight camera cable aside.
  12. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: 步骤 12 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: 步骤 12 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, AirPort Board Assembly: 步骤 12 中的图像 3,3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the socket closest to the ports.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  13. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 13 中的图像 1,1
    • Move the antenna cables aside, clear of the AirPort board.
  14. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: 步骤 14 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: 步骤 14 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, Display Assembly: 步骤 14 中的图像 3,3
    • Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  15. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 15 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 15 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
  16. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 16 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 16 中的图像 2,2
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets.
  17. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 17 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 17 中的图像 2,2
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
  18. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 18 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 18 中的图像 2,2
    • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
  19. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 19 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 19 中的图像 2,2
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  20. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 20 中的图像 1,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 20 中的图像 2,3 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 20 中的图像 3,3
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
  21. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, LCD Cable: 步骤 21 中的图像 1,2 MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement, LCD Cable: 步骤 21 中的图像 2,2
    • With the display facing towards you and the plastic clutch cover down, grab the clutch cover and slide it all the way to the right, towards the hinge.
    • Lift the plastic cover from the bottom and remove it from the display.
  22. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 22 中的图像 1,1
    • Peel up the tape covering the cable connector.
  23. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 23 中的图像 1,1
    • Remove the two screws securing the cable to the case:
    • Two T8 Torx screws.
  24. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 24 中的图像 1,1
    • Remove the six screws securing the antenna assembly in place:
    • Six PH00 Phillips screws.
    • Lift the antenna assembly to reveal the LCD cable connector underneath the left side.
  25. MacBook Pro 13" Retina Display Late 2012 LCD Cable Replacement: 步骤 25 中的图像 1,1
    • Grab the metal bar securing the LCD cable connector in place and rotate it towards the bottom of the display.
    • Pull the LCD cable straight out of its socket on the display.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the display.
结论
4等其他人完成本指南。
Jonah Aragon
于08/05/18注册
5,699 声望
创作了5篇指南
团队
Experimax Coon Rapids Experimax Coon Rapids 的会员
Business
3 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 84
总计 6,819
