跳转到主内容
MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement
你所需要的
  1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 步骤 3 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 步骤 3 中的图像 2,2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
结论
27等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
5条评论
Nice………………..!
Fred Starbuck - 回复
The bottom left-middle screw on my case is jammed and won’t come out—the more I try, the more I’m stripping it. Every other screw has been removed successfully, several times, with no problems. I wonder if I put in the wrong screw from somewhere else? Any ideas for removing it?
Jordan - 回复
do i get a laptop cover for mac book pro retina a 1502 model
naga usha - 回复
do i get a macbook pro retina A 1502 MODEL laptop cover (hard or soft shell)
naga usha - 回复
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
Jorge Ramirez-Centeno - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 71
过去 30 天: 318
总计 50,567
