跳转到主内容
MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement, Logic Board Assembly: 步骤 1 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement, Logic Board Assembly: 步骤 1 中的图像 2,2
    • Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
    • Remove the I/O board cable bracket.
  2. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 2 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 2 中的图像 2,2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  3. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 3 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 3 中的图像 2,2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  4. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 4 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
  5. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 5 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 5 中的图像 2,2
    • With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 6 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 6 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
  7. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 7 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 7 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 7 中的图像 3,3
    • Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
  8. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 8 中的图像 2,2
    • Carefully pull the DC-In board connector straight out of its socket on the logic board.
  9. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 9 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 9 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 9 中的图像 3,3
    • Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
  10. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 10 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 10 中的图像 2,2
    • If necessary, peel back any tape covering the microphone cable ZIF connector.
  11. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 11 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 11 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 11 中的图像 3,3
    • Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
    • Pull the microphone cable out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 12 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 12 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 12 中的图像 3,3
    • If necessary, peel back any tape covering the keyboard cable connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  13. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 13 中的图像 1,2 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 13 中的图像 2,2
    • Pull the keyboard cable straight out of its ZIF socket on the logic board.
  14. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 14 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 14 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 14 中的图像 3,3
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
    • Fold the cable out back over the battery to clear the way for the logic board.
  15. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 15 中的图像 1,1
    • Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
  16. MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 16 中的图像 1,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 16 中的图像 2,3 MacBook Pro 13" Retina Display Early 2015 Logic Board Assembly Replacement: 步骤 16 中的图像 3,3
    • Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
    • Remove the logic board.
结论
另外一个人完成了本指南。
Sam Goldheart
于10/18/12注册
465,602 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 175
