跳转到主内容
MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement
你所需要的
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Early 2013 Lower Case Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
结论
3等其他人完成本指南。
Sam Goldheart
于10/18/12注册
457,136 声望
创作了537篇指南
团队
iFixit iFixit 的会员
Community
139 名成员
创作了16,883篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 45
总计 10,333
