简介
Use this guide to replace the antenna cable assembly of your non-Touch Bar MacBook Pro (13-inch, 2016, Two Thunderbolt 3 ports).
For your safety, drain your MacBook Pro’s battery to 25% charge or less before you begin.
你所需要的
Power on your Mac and launch Terminal.
Copy and paste the following command (or type it exactly) into Terminal:
sudo nvram AutoBoot=%00
Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
sudo nvram AutoBoot=%03
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a P5 Pentalobe driver to remove the six screws securing the lower case:
Two 6.2 mm screws
Two 5.3 mm screws
Two 3.4 mm screws
Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
Remove the tape.
Remove the four 1.9 mm T3 Torx screws securing the plastic covers on top of the display hinges.
Remove both plastic hinge covers.
Remove the two 2.9 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
Remove the cover.
Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cables.
Use a pair of tweezers to remove the two aluminium covers.
Remove the two 3.3 mm T5 Torx screws (one from each side) securing the antenna cable assembly.
Also remove the two 4.1 mm T5 Torx screws (one from each side).
Remove the twelve 1.1 mm P2 pentalobe screws (six from each side) securing the rest of the antenna cable assembly.
Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
Slide your tweezers or spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
Use an opening pick to lever out the antenna cable assembly in the areas shown.
Carefully remove the antenna assembly, while simultaneously feeding the antenna cable bundle through the hole in the chassis.
另外一个人完成了本指南。
