简介
使用这篇指南更换背盖。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
将固定在顶盖和背盖的螺丝卸除:
两个 2.3mm的P5五角螺丝
八个3.0mm的P5五角螺丝
即将完成!
请按逆序重新组装设备。
结论
请按逆序重新组装设备。
7等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
Toby Thurston - 回复
Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
timofej.se -
This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
Susan Greer - 回复
It would be a good idea if people recorded in the comments which screws go where so that, if someone lost their screw positions, they could recover them from the comments.
Raymond Shpeley - 回复
