我们虽然已经这么做过七次,但拆解一个13英寸的专业级的苹果笔记本的确是一件有趣的乐事
让我们看看最新的技术规格:
13.3英寸的2560*1600像素227PPI的Retina显示屏
2.4GHz或2.6GHz的双核Intel Core i5处理器(可选2.8GHz的双核Intel Core i7处理器)
4GB、8GB或16GB的板载DDR3L内存
128GB、256GB、512GB或1TB的PCIe SSD硬盘
Intel的Iris核芯显卡
雷电2、USB3.0以及全尺寸的HDMI接口
打开之后,可以看到在内部没有我们任何让我们惊喜的地方。只有。。。失望
到现在为止,我们甚至还没有发现任何能令我们惊讶的事物。只是...... 失望
苹果的假日重新装修并未停止:重新布线、移位了的SSD以及大幅修改了的电池
Does anybody notice there is a small connector sitting right above the SSD in step 3? I just noticed it after opening my own MBP. What's it for? Diagnostic? It's gone in 2015 models.
我们断开天线电缆并拔出了AirPort卡
别担心——我们会将它放回去的
它也许可以被放置在旧机器里相同的位置上,但博通的 BCM94360CS 是一个不同的东西
新的802.11ac Wi-Fi技术可以提供三倍于802.11n的连接速度
There are three antennas, I think. They can be seen on the first picture at step five.
Are these antenna's going into the plastic part underneath the screen?
固态硬盘可能不会像其他硬盘驱动器的旋转,但13英寸MacBook Pro Retina中的SSD肯定不喜欢来回跳动
这款Pro配备有128 GB的闪存,更大的型号为256或512 GB
值得注意的点点滴滴:
SanDisk的 05131 016G 的16GB NAND闪存(共有 8 * 16GB = 128GB)
Marvell半导体的 88SS9183 SSD控制器
SK Hynix的 H5TQ2G63DFR DDR3-1600缓存
Since you have torn down both the new 13" and 15" rMBPs, can you advise whether the PCIe SSD modules are cross-compatible between models (and with the mid 2013 Airs)? I.e do they use the same PCIe connector and are they the same physical size?
I would hope after much chopping and changing that Apple has finally settled on a common module design, making it easier to repair / upgrade one of the few remaining user-replaceable parts.
i just bought a MBP today, and i think the SSD size will be a problem for me in some years because i bought the 128GB model, do you think that i would can buy a new SSD in the future?
So, is the SSD in fact upgradable and can someone give example of where to get modules?
It is indeed upgradeable, Transcend is on to it. But as long as the SSD-controllers are rare it will take some time.
What's that RAM module here? I've seen the main RAM solded on de MB...
羽加迪姆勒维奥萨(什么鬼)! I/O板电缆几乎从插座上滑出
我们得心应手的专业技术螺丝刀使扬声器的拆卸看起来像魔术
另一场嗖嗖声和一声轻弹,扬声器被从取了出来出来
我们很高兴地说,那些不能被命名的扬声器相当容易被移除——不需要黑暗魔法
How easy is the speakers removal? But it is difficult to return back
Can you help
更糟糕的是,去年的电池球童已经在触控板上移动,把可怜的东西活埋了。(真不知道怎么翻译了)
我们与朋友、iOpener和塑料卡片一起发起了拆除行动,经过耐心的努力,我们开始工作
胜利!最后,笨拙的电池组被从箱子里拿出来
Hi iFixers,
Spilling half a glass of sparkling water on a MBP-13" retina (late 2013) is not best idea. Washing and drying all PCBs got it back to work for few months, but recently battery stoped charging. I noticed few pins around one SMD chip of battery charging controller were corroded. I got an iOpener kit and a new battery.
I can say iOpener is fantastic. Although I did not use much plastic card part of the tool kit as it is difficult to insert between case edges and smallest batteries on each side. Instead I used a rectangular painting palette knife (2 1/2 x 1/2 in) which is quite flexible and perfect dimension. It took me around 30 minutes to get old battery pack out, reheating iOpener 4 or 5 times, inserting palette gently under each cells (one by one) and slowly rocking palette underneath to gradually cut melted glue layer.
MBP works again as a new one, charging happily.
Thanks to iFixit guys....
Pierre d, Aug 12, 2014
Hi,
Where did you buy your new battery? My battery stopped working after I dropped water on my computer.
Thank you,
我们从取下了散热模块,取出导热铜管,以发现……粘稠的导热硅脂
处理器和核心显卡在右边共享一块芯片,左边的是南桥(PCH)
Occurs to me that replacing thermal paste would be 6 out of 10 repairability. Do you concur?
The GPU does not make any contact with the heat spreader. It will have a sudden death leaving the main board as a wreck. Stupid design.
Typing this on a well-worn 7 year-old Late 2013 MacBook Pro and my GPU hasn’t died yet
接下来我们要检查I/O板
有这些芯片
Parade Technology的PS8401A HDMI抖动清洁中继器
NXP Semiconductors 的 PCA9501 8位I/O扩展器,它带有一个2-kbit的EEPROM
Genesys Logic 的 GL3219 SDXC读卡器
Hey hello,
Have question about the pins on the Logic Board you have 5 of it totally they are with spring like a button where are they for? 1 of mine is broken can that be the reason my mac is not booting any more?
Regards,
Base
Flexible ground contact with the rear case. Macbook should boot without them, as it can boot without the rear case.
在逻辑板的背面有:
Micron D9PXV 512 MB DDR3L 内存
MXIC MX25L6406E 64M CMOS 芯片
德州仪器(TI)的 Stellaris LM4FS1EH 微控制器
Cypress CY8C24794-24LTXI 可编程芯片系统
博通 BCM15700A2
P13WVR 12612NEE
Linear Technology(线性技术) LT3957 B29255
视网膜版 13英寸 MacBook Pro (2013年晚期)的可修复性评分是1 / 10(10是最容易修复的)
专用的防撬螺丝继续使打开设备变得不必要的困难
电池组件现在已经完全,而且非常牢固地粘在外壳上,从而使替换变得复杂。此外,电池现在还能覆盖固定触摸板的螺丝和电缆。没有先移开电池,不可能更换触摸板
视网膜显示器是一个没有保护层的整体。如果在显示中出现任何问题,则需要替换整个显示屏(¥¥¥)
在MacBook Air的先例下,RAM被焊接到逻辑板上。现在为升级付费,或者永远保持4 GB。没有升级的机会
专有的SSD现在是PCIe格式,但仍然不是标准驱动器。为未来的兼容驱动器等待;现在,你只能坚持自己拥有的东西
Heng,
From the Ars Technica review of this iFixit teardown: "the CPU and GPU on one long die and the chipset in a second, smaller die". From the iFixit photo the CPU/GPU chip has the thermal goop on it to connect to the heat sink and the chip set does not. This makes sense as the CPU/GPU die is a much bigger power/thermal hog than the chip set.
I have the same model (128G). My technician says he can take out the 128G and put a 512, 8G RAM or a 256, 8G RAM. Is this true?
yes it is possible... you can do it by yourself... you have just to follow the guide until the step 7, replace your 128 gb ssd with another one...
be careful to buy the right ssd... on the very top of this page there is the bottom "PARTS", there you can find the ssd and chose the one that you prefer! when you have to reinstall the OS X, no problem because at the first start you can download it directly from the apple server!
Giorgio -
Thanks Giorgio,
I needed the assurance. This means a lot. Thanks again
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
31条评论
Not sure if this is something you guys at iFixit have considered as far as environmental impact is concerned (and I could be wrong here as i don't know the process myself). If something needs to be replaced on an Apple product and is returned under warranty or Apple care then the entire unit is replaced for the customer. The defective unit is then repaired, refurbished and resold to the consumer at a refurbished price. That still results in that particular piece of technology being out there in use and not on a scrap heap.
Again I'm not sure if I am missing something in the process here but this seems like a decent way to keep technology in circulation and off the scrap heap, at least if it's covered under warranty or apple care.
Hello Garreth!
I think what’s missing is the ability to fix it yourself to save some cash when it’s out of warranty.
Abdoz A -
I just had to change my 2011 macbook pro 13 inch battery as it was getting pitiful, if there is no way of easily changing the battery it will probably be the last macbook I buy
Is the CPU user replaceable or is it soldered onto the board?
Thanks Apple. Not only are Mac OS and iOS converging but you are turning your laptops into iDevices, ensuring consumers will buy new laptops when they realize that 4 gigs of RAM and/or a 128 GB SSD are not sufficient to run certain apps.
Surely it should not be so difficult to make SDRAM slots and a SSD slot accessible and your designers should be able to come up with a way that will not mess up the aestetics.
Add a 5 YO kid, a sick Lego mini-figure (from now, the patient), an ambulance to move the patient and a hospital, and it will end up in...
YES! A BROKEN SCREEN! My MBPr13 Late 2013 was the hospital, he laid the patient on top of keys 9 and 0 and "closed the chamber". A 700$ hit. Realized how it happened, because of the small circle marks left on the keyboard protector
It's possible to have two hard drives on this model?
Arnold Roa - 回复
well, at part 20, you have wrong angle at your SSD, it should be....
I've owned stores in florida and ohio. I'm old. I must say though, throughout the years mac and microsoft have earned the epithet of being nothing more than profiteering low-down capitalists that we ought to put down permanently (for a myriad of reasons). Linux is the closest thing to an answer I've yet to find out there (ironically barely a hint of being an option in this "free-trade" system of plutocracy which has us all scrambling between rocks and hard places).
As for mac, they earn a higher level of distrust. Why would the enterprising entity want to use unorthodox screw heads if not for manipulation for higher proceeds? We all know the answer but dare not break free from the mold to point our customers in a better direction. Why would an entity want to keep its own customers from accessing (changing/replacing) their own battery or upgrading their own ram or replacing their own drive?). Racketeering with a stolen op sys; Imagine buying a house only to be locked out later. Thanks ifixit
Why for there are 9 indentical DDR3L SDRAM chips if there are only 8 and 16 GB RAM models? if each chip is 512MB so it results in 8.5 GB RAM instead of 8. Is this a rescue one like the spare wheel on a car?
Do you carry the replacement display for this model, i can’t seem to find it on your site
Hi Omar, here is the product page. They’re currently out of stock, but you can be added to the notify list.
I am not going to lie, but the whole time I was reading this teardown process I was laughing out loud the whole time. The Harry Potter references were just spot on! Thank for fantastic teardown.
