跳转到主内容
MacBook Pro 13“一体式 2009 更换电池
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. MacBook Pro 13“一体式 2009 更换电池, 电池: 步骤 1 中的图像 1,1
    • 为了预防意外发生,我们建议您从逻辑板上断开电池连接器,以避免任何放电。
    • 使用一个平端撬棒将电池连接器分离逻辑板插座。
    来自 gansodesoya 的话:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 回复
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 回复
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 回复
结论
将您的设备,遵循这些指示,逆序重组。
3等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leeroy_正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 5,302
